1986 Toyota Tercel Overheating
13,000 MILES • 4 CYL • FWD • AUTOMATIC
MELCAT
The car overheats after only a few blocks and the check engine light comes on. The Owner's Manual shows a thing between the radiator and the battery. On the drawing there is a connection to this bottle type thingy, and the radiator. If this thingy is missing, could this make the car over heat and the engine light come on?
Sincerely,
Melanie McDonald
Feb 4, 2009 at 8:27 AM
  • 75,988 POSTS
You must be talking about the coolant resevoir bottle.
Try replacing the thermostat and make sure the radiator is filled properly then comeback if it continues to overheat
Feb 4, 2009 at 8:41 AM
