1999 Toyota Tazz Running cold indicated on Temp Guage
OOMTOM
Engine Mechanical problem
1999 Toyota Tazz 4 cyl Two Wheel Drive Manual
How do you check if the engine is running cold or whether the temperature sensor is faulty.
Jun 14, 2010 at 7:19 PM
BLACKOP555
  • 10,386 POSTS
run engine till it feels warm and touch hoses by hand should be pretty hot. or you can use a heat gun and measure heat and compare it.
or you can take sensor out and put it in boiling water while its connected to its harness and see if it jumps up to hot.
Jun 15, 2010 at 2:09 PM
