1987 Toyota Tarago Car runs fine, but won't start once i tu
LAMAMU
Engine Performance problem
1987 Toyota Tarago 4 cyl Two Wheel Drive Automatic
my car runs fine, will start with no problems, but once i turn it off, it wont start again for 30-60 minutes. after that amount of time, it will start with no problems. it tries to start, it just doesnt catch.. please help
May 16, 2010 at 1:48 PM
  • 75,988 POSTS
Next time it refuses to start don't wait do below immediately to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 16, 2010 at 5:19 PM
