1986 Toyota Tarago power steer conversion
CRACKERS312
Steering problem
1986 Toyota Tarago 4 cyl Two Wheel Drive Manual
I have a toyota tarago (1986). When cornering it finds a stiff spot and wont self correct easily, could it be tie rod ends? (non power steering) I have another van with power steering how big a job is it to convert?
Feb 21, 2010 at 11:00 AM
  • 31,937 POSTS
Hi there,
Faulty tie rod ends would not produce this type of problem, it could well be a fault in the box, it is adjustable, this should be done by a qualified mechanic, as for the conversion, it will take you the best part of a day if you are well equipped, it is not hard just time consuming.
mark (mhpautos)
Feb 21, 2010 at 8:36 PM
