2007 Toyota Tacoma lifter noise
2007 TOYOTA TACOMA
50,000 MILES • 6 CYL • 4WD • MANUAL
CFORBES421
lifters are coming out of adjustment. dont know where to get the shims and need to figure out what they need to be set at. thanks
Jun 9, 2009 at 5:35 AM
DOCFIXIT
  • 18,828 POSTS
Hi
If you have a 1GR-FE engine the valve clearences cold are Intake .15 to .25 mm(.006 to .010 in)
Exhaust .29 to .39mm ( .011 to .015 in). If out record reading lifters are replaced no shims and dealer is your source. This is a major job lots of stuff to take off and cams are removed to get at lifters.
If you want instructio click on link at bottom of post and you can get Mitchell on demand.
Hope this helps
Jun 10, 2009 at 3:15 AM
