2006 Toyota Tacoma outdoor temperature gauge
2006 TOYOTA TACOMA
54,000 MILES • 6 CYL • 4WD • AUTOMATIC
COPPER0662
The readout on my exterior temperature and compass stopped working. Everything else seems to work. Is there a separate fuse for just that LED or is it a wiring problem? How should I fix it.
Apr 9, 2010 at 5:26 PM
TACOBOY
  • 6 POSTS
These are repairable. If you re-solder the surface mount resistors, the unit will generally quickly fail again due to oxidation on the old components.
Jan 6, 2011 at 1:54 PM
