2006 Toyota Tacoma High and Low setting wont work
60,000 MILES • 4 CYL • 4WD • MANUAL
AMAN117
We think it may be something with the fuse but out tacomas AC will only run high and not medium and low
Aug 29, 2009 at 4:03 AM
KHLOW2008
  • 41,812 POSTS
Hi aman117,
Seems the blower resistor is faulty and requires replacement.
Aug 30, 2009 at 9:00 PM
ELSWARRO
Just had the same thing happen to my truck (exact same model and mileage) today. Is replacing a blower resistor a hard/expensive thing to do? should i take it in or try to do it myself? thanks in advance!
Sep 27, 2009 at 2:58 PM
KHLOW2008
  • 41,812 POSTS
Hi elswarro, Replacing the resistor is not too difficult. I do not have the complete removal procedures but here are some diagrams that should be helpful.
https://images.2carpros.com/forum/automotive_pictures/192750_ACComp06TacomaFig05_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_BlowerResistor06TacomaFig73_1.jpg
Removing the 2 bolts and you can lift the resistor out. The cabin filter has to be removed for easier access to the resistor.
Sep 28, 2009 at 2:51 AM
ELSWARRO
awesome thanks!
Sep 28, 2009 at 4:41 AM
