2006 Toyota Tacoma cold air intake
44,000 MILES • 6 CYL • 2WD • AUTOMATIC
FISINGSCOOTER53
I have been looking at buying a cold air intake and i need to know if they really can save you fuel...i dry my truck very easy and dont get into it very much...i average around 21 mpg...it would be great if i could get around 24 or 25....thanks
Feb 16, 2009 at 10:12 PM
2CARPRO JACK
  • 11,533 POSTS
Im not sure if you will get another 3-4 mpg, that is quite an increase.It should get you a little, so will a cat-back exhaust system. Do you have car or truck tires on it? ie; P245 is a pass car and a LT245 is a truck, the difference being the truck tires usually have higher air pressure ratings and will roll with less resistance
Feb 16, 2009 at 11:48 PM
FISINGSCOOTER53
well i just recently put 265 70 on my truck...but im just worried that cold air intakes aren't good for your vehicle
Feb 17, 2009 at 2:32 AM
2CARPRO JACK
  • 11,533 POSTS
The only thing they could hurt is the ability of moisture to get into the intake system, other than that, they dont hurt anything
Feb 17, 2009 at 3:27 AM
KARENCAREN
  • 72 POSTS
If you put in a cold air intake I think you will get at least 1-2 more mpg. Not that big but it will help you save money.
Mar 25, 2009 at 5:14 PM
MBOROKI
  • 14 POSTS
Cold air intakes do reduce fuel economy especially if you get the right type. I have been using Volant Cold Air Intakes and it not only reduces my fuel intake but also increases my vehicles horsepower and torque.
Mar 8, 2013 at 1:16 AM
