1998 Toyota Tacoma MAF sensor wiring
1998 TOYOTA TACOMA
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
RHOFFLAND
can you by any chance tell me what wire is the signal wire and which is the ground wire on a mass air flow sensor plug (numbered from left to right looking at it from the front or the specific colors) on a 98 toyota tacoma prerunner 2 wheel drive 2.7 liter? thanks!
Sep 11, 2010 at 3:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle's MAF sensor has 5 wires.
white/red is part of the IAC valve wiring
yellow/green goes to the ECM
brown/black goes to the A/T oil temp sensor
brown/white goes to the ECM
grey/red goes to the ECM
Sep 28, 2010 at 3:05 PM
