2006 Toyota Tacoma BLOWER FAN
2006 TOYOTA TACOMA
80,000 MILES • 4 CYL • 2WD • MANUAL
R H THIGPEN
BLOWER FAN WORKED YESTERDAY. WILL NOT COME ON TODAY. THE AC IS WORKING BUT THE FAN WILL NOT COME ON TO BLOW THE COOL AIR. I THINK THAT I HAVE CHECKED THE FUSES. WHAT DO I NEED TO CHECK NEST. HOW MANY FUSES ARE INVOLVED WITH THE FAN OPERATION? DID I CHECK THE RIGHT ONES?
May 4, 2010 at 6:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check 10 amp fuse labeled A/C in the engine room junction block, left side of engine compartment. also check 50 amp fuse labeled HEATER in the same junction block.
If both are OK check the blower motor relay.
May 4, 2010 at 4:26 PM
