2005 Toyota Tacoma wheel nuts
HAN_S
2005 Toyota Tacoma
i need to use an m12*1.75 lug nut on a wheel which usually uses an m12*1.5.
If i change the stud to an m12*1.75, will this still work?
Jan 4, 2009 at 12:00 PM
  • 31,937 POSTS
Hi there,
As long as the taper on the nut is correct and matches the rim, you should not have a problem.
mark (mhpautos)
Jan 4, 2009 at 12:05 PM
HAN_S
do you mean if it is an acorn or flat faced lug nut etc?
or is there a thread in the wheel i need to account for?
Jan 4, 2009 at 12:22 PM
