2005 Toyota Tacoma REPLACEMENT OF DRIVER SIDE MIRROR
2005 TOYOTA TACOMA
36,000 MILES • 6 CYL • 4WD • MANUAL
BAYLEEGIRL
I need some help with replacing the driver side mirror- does the entire door panel have to be removed? Is it possible just to remove the upper portion of the door panel?
Feb 17, 2009 at 5:16 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me if your model is just a Tacoma, or Prerunner, orX-Runner. Also your engine size in liter and the 8th digit of your VIN.
Feb 17, 2009 at 5:41 AM
BAYLEEGIRL
The truck is a Tacoma
the engine size, in liters, is 4.0
the eighth digit is "N"
Feb 17, 2009 at 9:26 AM
IMPALASS
  • 3,112 POSTS
Hello - Thanks for getting back with me. I have attached the directions we have with pics..........hope this helps. OUTER REAR VIEW MIRROR ASSY LH COMPONENTS Fig. 51: Identifying Outer Rear View Mirror Assy LH Components Courtesy of TOYOTA MOTOR SALES, U.S.A., INC. REPLACEMENT
https://images.2carpros.com/forum/automotive_pictures/248015_1_167.jpg
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL 2. REMOVE FRONT DOOR LOWER FRAME BRACKET GARNISH LH 3. REMOVE FRONT DOOR WINDOW REGULATOR HANDLE ASSY 4. REMOVE DOOR ASSIST GRIP COVER LH 5. REMOVE FRONT ARMREST BASE PANEL SUB-ASSY UPPER LH 6. REMOVE FRONT DOOR TRIM PANEL ASSY LH 7. REMOVE OUTER REAR VIEW MIRROR ASSY LH a. Disconnect the outer rear view mirror connector (w/Power mirror). b. Remove the 3 nuts. c. Disengage the claw and remove the outer rear view mirror. Fig. 52: Removing Outer Rear View Mirror Assy LH Nuts Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.
https://images.2carpros.com/forum/automotive_pictures/248015_2_112.jpg
8. REMOVE OUTER REAR VIEW MIRROR LH . Apply protective tape to the outer circumference of the outer rear view mirror, as shown . See Fig. 53.
https://images.2carpros.com/forum/automotive_pictures/248015_3_77.jpg
a. Using a screwdriver with its tip taped in protective tape, disengage the 2 claws. b. Disengage the 2 claws and remove the outer rear view mirror. Fig. 53: Removing Outer Rear View Mirror LH Claws Courtesy of TOYOTA MOTOR SALES, U.S.A., INC. 9. INSTALL OUTER REAR VIEW MIRROR LH . Engage the 2 claws into the outer rear view mirror. a. Engage the 2 claws and install the outer rear view mirror. Fig. 54: Engaging Claws Into Outer Rear View Mirror Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.
https://images.2carpros.com/forum/automotive_pictures/248015_4_52.jpg
10. INSTALL OUTER REAR VIEW MIRROR ASSY LH . Engage the claw and install the outer rear view mirror. a. Tighten the 3 nuts. Torque: 8.0 N.m (80 kgf.cm, 71 in.lbf) b. Connect the outer rear view mirror connector (w/Power Mirror). Fig. 55: Tightening Outer Rear View Mirror Assy LH Nuts Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.
https://images.2carpros.com/forum/automotive_pictures/248015_5_34.jpg
11. INSTALL FRONT DOOR TRIM PANEL ASSY LH 12. INSTALL FRONT ARMREST BASE PANEL SUB-ASSY UPPER LH 13. INSTALL DOOR ASSIST GRIP COVER LH 14. INSTALL FRONT DOOR WINDOW REGULATOR HANDLE ASSY 15. INSTALL FRONT DOOR LOWER FRAME BRACKET GARNISH LH 16. CONNECT CABLE TO NEGATIVE BATTERY TERMINAL Torque: 3.9 N.m (40 kgf.cm, 35 in.lbf)
Feb 17, 2009 at 12:11 PM
BAYLEEGIRL
Thanks for your help thus far. My real difficulty is getting the door panels off--could you provide a clearer graphic of that process? The subsequent graphics of the actual R&R are terrific, but the door graphic, even when enlarged, is extremely difficullt to visualize. Thanks for your efforts on my behalf.
Feb 20, 2009 at 12:24 AM
IMPALASS
  • 3,112 POSTS
Hello - Is this the pic you are talking about? I had to break it down into 3 parts.........so overlap and piece together. If this does not work go into the PM and send me your email address and I will try that way. If that doesn't work we can try a fax if you have a number.
https://images.2carpros.com/forum/automotive_pictures/248015_Picture1_57.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture2_43.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture3_28.jpg
Feb 20, 2009 at 8:24 AM
