2005 Toyota Tacoma Rear Brakes
2005 TOYOTA TACOMA
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
RT#
I took the hub off my rear brakes to check for a squeak when I brake, brake shoes were in good cond. so I cleaned them with brake cleaner and put the hub back on, after hub and tire were put on I drove my truck and the brake pedal was going all the way to the floor and the parking brake was not working at all, any suggestions what might have happen? I bled the brakes but did not do any good.I appreciate any suggestions thank you R.T.
Jan 24, 2009 at 8:18 PM
MASTERTECHTIM
  • 4,750 POSTS
theself adjust allen off inside drum. take apart again and let me know
Jan 24, 2009 at 9:51 PM
RT#
[quote:556a25e0c6="mastertechtim"]theself adjust allen off inside drum. take apart again and let me know[/quote:556a25e0c6]
Thank you for the feedback I will take apart again see if I missed anyhing I will get back to you with the results Thanks again. R.T.
Jan 25, 2009 at 5:40 AM
