I just put a new rebuilt starter in. Turn the key and zippo,nothing. Batties good,checked fuses. Bad starter?
Jun 23, 2010 at 11:48 AM
✓Experienced Mechanic
You sure its not an anti theft device problem? If not do below
If the battery and connections are good-start by checking the starter inhibitor switch, starter relay,transmission range switch and igntion switch-last the starter motor
