2002 Toyota Tacoma over heating
WAKERIDA97
2002 Toyota Tacoma 6 cyl Four Wheel Drive
I have a 2002 toyota tacoma supercharged and after driving it for about 10 minutes the temperture goes to right below the red and if i turn the heater on it goes down but still runs a little hot. I have already replaced the thermostat and ratiator what else can i try to do?
Dec 3, 2008 at 7:41 AM
  • 75,988 POSTS
Could be air lock in the system try bleeding it-don't work -get it block and pressure tested.
Dec 3, 2008 at 7:47 AM
WAKERIDA97
I bleed the system and got the block presure tested and both of those checked out good, anything else that I might try?
Dec 3, 2008 at 8:23 AM
  • 75,988 POSTS
Are you actually overheating-boilover-could be the engine temperature gauge sender acting up or the coolant temperature sensor-
Dec 3, 2008 at 8:28 AM
WAKERIDA97
I bought it a couple weeks ago and the toyota dealership said it was something in the supercharger or the block. and it boils over after about 20 minutes of driving unless i turn the heater on high, and it comes back down a bit. could it have anything to do with the supercharger or something else?
Dec 3, 2008 at 9:20 AM
