Replaced cracked head. 2.7L dual OHC engine.
When hash marks on both cams are alligned, Crank mark is off, not zero! Moving the timeing chain ONE link forward gives me a crank reading of 15 BDC, go the other way and I get 5 ADC! The chain has NO play or slop. Any thoughts on what could be wrong, and/or how to fix this problem?
NO work was done to the bottom half of the motor.
Thank you
Can I safely run it at 15 off????
Thank you
Apr 22, 2010 at 7:03 AM
