2002 Toyota Tacoma fuel problem
189,000 MILES • 4 CYL • 2WD • MANUAL
BERGMANEP
The truck suddenly sputtered and died. Can't start. It might run for 2-3 seconds then dies. I changed the under manifold fuel filter...the fuel pump relay...and the fuel pressure regulator...still does the same...are there any other possibilities other than the pump...?(yes, I do feel"fuelish" for not testing the pump first)...thanks...
Jun 23, 2010 at 11:46 AM
  • 75,988 POSTS
To find out if its the fuel pump do a fuel pressure check with a fuel pressure gauge designed for our system
Jun 23, 2010 at 12:04 PM
