2001 Toyota Tacoma Water dripping on the passenger side flo
2001 TOYOTA TACOMA
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
CMCKENNA
I notice when the air conditioner is running I'm getting water dripping on the passenger side floor comming from the floor vent and what looks like an air intake plastic box under the dash. I don't notice any dripping on the ground where it normally drips. Not sure if something is clogged or what would cause this. Is this a complicated fix (removing dash) or I'm hoping an easy fix that I can do myself. Please advise
Thank you,
Cathy
May 4, 2010 at 6:23 AM
If its water check the AC drain tube now if its coolant its coming from the heater core
May 10, 2010 at 8:50 PM
