The truck runs like a champ, no signs of any trouble, I keep up with maintenance and there is just this one issue with it stalling. It only happens when I stomp on the gas for like 2-5 seconds, pedal to the medal and completely let off. 2-3 seconds after the engine completely dies. Doesn't sputter, or anything, just dies. All electrical things are still working through out this all. I pull over then I am unable to get it to start. It cranks, and cranks, the only way I'm able to get it to start is if I give it gas, keeping the RPM's up and shortly dying off of idle several times. So with this repeat process for about 5 min. It will return to normal as if nothing ever happened. I was told that it might be the IAC valve, maybe the EGR valve? What do you guys think?
Feb 2, 2009 at 2:58 PM
