2001 Toyota Tacoma Headlights go out periodically
143,000 MILES • 4 CYL • 2WD • MANUAL
WHYEMIER
When I'm driving with the headlights on at night they will go out, along with the dash lights, about 35 minutes into my drive. I can immediately turn the light switch off and back on and they will come on again. After another 35 minutes they will again go off. Thiis can be repeated indefinitely on a long night drive like "Old Faithful" every 35 min. I have already replaced the 'Head Light Control Relay' in the fuse/relay box under the hood. This had no positive results other than letting me know I had replaced a good relay.
Apr 23, 2010 at 4:42 AM
FORDRACING24
  • 65 POSTS
Sounds like a connector is loose. I'm not sure if the dash would be linked with the wire for the headlights but headlights going out periodically are usually from a loose connection. You can check a wiring diagram to see if they're linked, if they are that's most likely your problem.
Jun 18, 2010 at 5:34 AM
ALSPROST
did you ever find out what was causing this, I have the exact same thing happening on my 03.
Thanks
Jan 31, 2020 at 12:33 AM
STEVE W.
  • 15,358 POSTS
ALSPROST Could you please provide a bit more vehicle detail please, 4cyl or 6 and do you have Daytime Running Lights or not? Are yours acting the same in regard to the time interval? Also does it matter if it's high or low beam?
Jan 31, 2020 at 7:26 AM
ALSPROST
Hi Steve,
2003 Tacoma 4cly 2.7L no daytime running lights. Same.time interval ~30 minutes. When it goes dash, high, and low go. Don't know whether rear goes or not. Off /on with rotary fixes every time so far.
Jan 31, 2020 at 8:27 AM
STEVE W.
  • 15,358 POSTS
Okay, from the two descriptions I would say there is a problem in the switch or the body control module. Those are the only two components shared between the interior lights and the headlights. Plus because of the failure modes I would suspect the body control module more than the switch and that it comes right back on when you turn it on and off.
If it was in the switch and heat related it would come back on as soon as it cooled and turning it off and on wouldn't change that.
Jan 31, 2020 at 11:46 AM
ALSPROST
For posterity the culprit was a bad fuse for the ECM module. Replaced that and the headlights stay on now.
Dec 19, 2020 at 6:02 AM
STEVE W.
  • 15,358 POSTS
Thanks for the update.
Dec 19, 2020 at 12:00 PM
