2001 Toyota Tacoma dome light
65,650 MILES • 6 CYL • FWD • AUTOMATIC
JAMESRCOLLIER
how does one change an apparent burned out jight bulb? I can't get the lens cover off
Dec 9, 2008 at 7:33 AM
THIS IS MIKE
  • 686 POSTS
Usually the dome light cover will have a small opening where you can use a flat bladee screw driver to pop it off. It will just press back on and lock after you change the bulb.
Dec 9, 2008 at 8:09 AM
