2000 Toyota Tacoma Transmission Oil Pan
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKETM3
Its stuck
Jun 21, 2010 at 5:15 AM
DOCFIXIT
  • 18,828 POSTS
Smite with a rubber mallot if no go tap the thinest putty blade into gasket. Heads up put two bolts in front of pan so when it brakes loose you don't eat ATF
Jun 21, 2010 at 7:06 AM
