2000 Toyota Tacoma P0770
JP007
  • 2000 TOYOTA TACOMA
  • 6 CYL
  • 106,000 MILES
I have a 2000 Toyota Tacoma and my check engine light came on. Had the dealer check it and they said it was the P0770 code which means my Torque converter is not locking properly and suggested I replace the transmission. Can this be correct? I am driving it and I have had no problems with the transmission shifting properly. Everything seems to be fine. I had the transmission serviced 10000 miles ago. The check engine light is off now but can I still drive it? Should I have the transimission flushed again and see if it helps? Any help will be appriciated.
Friday, August 28th, 2009 AT 12:30 PM
DOCFIXIT
  • 18,828 POSTS
Well 770 is most likely the SLU solenoid sticking causing TC C not to lock up or release in programed time. Or a manual vale sticking. A trans is not need only testing of solenoids and replacing if needed or cleaning valve body. Get a second diagnosis from independent shop.
Friday, August 28th, 2009 AT 2:49 PM
