1999 Toyota Tacoma upper timing belt idler
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
DBAUMAN
Scraping noise
installed new one, noise stayed the same.
Removed it and installed another one, noise came back in two days.
I ran stethoscope on all the pulleys and this is the only one making the noise.
Is this a common problem?
What could be making this pulley make the grinding sound?
Is there something else I can do to repair it or stop the noise?
Mar 14, 2009 at 1:17 AM
2CARPRO JACK
  • 11,533 POSTS
To go through 3 of them is odd, are you sure the noise isnt transfering to that point? Did you check the tensioner wheel? Water pump maybe?
Mar 14, 2009 at 1:26 AM
DBAUMAN
It is quiet all around the water pump and the other pulleys. I replaced the timing belt and the bottom idler pulley. I can hear the noise on the crossover exhaust pipe with the stethoscope but the sound is really pronounced on the center bolt on the idler pulley.The idler pulleys I have removed are still smooth and turn easily. The sound gets quiet for a little while but comes right back. It doesn't seem to hurt anything but the sound is driving me nuts.
Mar 14, 2009 at 3:26 AM
2CARPRO JACK
  • 11,533 POSTS
Is it possibly an accessory transfering noise? maybe a cover rubbing?
Mar 14, 2009 at 4:09 AM
DBAUMAN
thank you very much for your trouble in answering my questions, I really appreciate it. the noise must be inside the engine
Mar 15, 2009 at 1:03 AM
