1999 Toyota Tacoma turn signal problem
113,000 MILES • 4 CYL • 4WD • MANUAL
TACOMA12
Why does my turn signal light up or stop flashing when I press the brake pedal? I replaced all of the bulbs with new ones and still have the problem.
Oct 17, 2009 at 2:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you have a ground problem, either at the brake light switch or at the turn signal switch.
Oct 17, 2009 at 2:29 AM
TACOMA12
[quote:43cfe22b3b="bluelightnin6"]you have a ground problem, either at the brake light switch or at the turn signal switch.[/quote:43cfe22b3b] Where is the brake light switch and turn signal switch grounds located?
Oct 17, 2009 at 11:07 PM
TACOMA12
where are the brake light switch and turn signal switch grounds located?
Oct 17, 2009 at 11:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
brake lamp switch is located at brake pedal arm, below driver dash. turn signal switch is what is used to operate signals. check at the switches first to ensure wiring is connected properly. if so, follow ground wire to ensure it is not damaged anywhere
Oct 18, 2009 at 1:52 AM
