1999 Toyota Tacoma Starter Replacement
1999 TOYOTA TACOMA
130,000 MILES • 4 CYL • 4WD • MANUAL
MATTHENSLEY
Can you tell me how to replace the starter in this vehicle?
Sep 17, 2010 at 7:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
First disconnect battery. There is a bolt to the frame on the bracket for the brake line. Remove it and pull the line out of the way. Next, remove the rubber sheeting around the opening. Now you will see a few 10 mm bolt heads, remove them and a small shield will come off exposing a cutout. With the cutout exposed you can now access the starter easier. Remove the starter electrical connectors and bolts then remove starter through access opening you made.
Sep 17, 2010 at 7:51 AM
