1999 Toyota Tacoma Overheating
1999 TOYOTA TACOMA
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHERIEN
Hello. I replaced the radiator and t-stat and continue to have overheating unless the heat is on. I do not see any type of smoke coming out from the exhaust so it does not appear to be a head gasket. I is making some sort of a whistling noise.
Any suggestions would be appreciated.
Sep 2, 2009 at 6:51 AM
Cooling fan or clutch fan/ radiator cap okay, and water pump functioning -could be airlock in the system try bleeding it-
Sep 2, 2009 at 7:56 AM
