1999 Toyota Tacoma No oil pressure.
188,000 MILES • 6 CYL • 4WD • MANUAL
ADHOLT1980
It had good oil pressure, but when I replaced the cam shaft seal on the front left side and put everything back together, the oil pressure stopped. Could something have happened while repairing it or could it have just happened on its own and how can I fix it? Thank you for your help.
Mar 1, 2010 at 9:04 AM
DOCFIXIT
  • 18,828 POSTS
Is oil pressure switch hooked up? Any engine noise?
Mar 2, 2010 at 7:22 AM
ADHOLT1980
Yes the oil pressure switch is hooked up and I even tried a oil gauge tha shows the exact pressure , and when you first start it it goes up to about 10 lbs of pressure for about a minute then bottoms out , and yes you can hear the lifters ticking and the rods starting to knock a little.
Mar 2, 2010 at 8:48 AM
DOCFIXIT
  • 18,828 POSTS
Can't think of what could have happened. The repair should have no effect on oil pressure. Only thing i can think of would be big leak at T belt tensioner but you would see oil running out.Was cam removed?
Mar 3, 2010 at 12:59 AM
ADHOLT1980
no the cam wasn't removed and the oil pump was never touched, no leaks are present but then again there is no oil pressure , is there anyway to check and see if it had spun the bearings or not , because if its the oil pump I can change it but if it is the bearings I would have to change engines. I did have to take off the valve covers , is there anyway something could have gotten blocked somewhere right there?
Mar 3, 2010 at 9:29 AM
DOCFIXIT
  • 18,828 POSTS
Possible let's do a test take off oil filler cap run engine is there pressure?
Mar 4, 2010 at 7:30 AM
ADHOLT1980
yes there is some pressure because there is oil coming out the hole, is there anyway to find out if it had spun a bearing or not?
Mar 4, 2010 at 12:14 PM
DOCFIXIT
  • 18,828 POSTS
Not without droping oil pan and inspecting each bearing. Check to see if PCV has suction on it.
Mar 5, 2010 at 8:09 AM
