1999 Toyota Tacoma Missing when accelerating
186,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHLAPJACKS
My alternator went out so I replaced it with new and the battery. Now it idles great but when I push the gas it chugs, misses, and back fires. Any ideas?
Aug 5, 2009 at 7:00 PM
  • 75,988 POSTS
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Aug 5, 2009 at 7:09 PM
