1999 Toyota Tacoma ignition
160,000 MILES • 4 CYL • 2WD • MANUAL
FLEIDINGER
vehicle will not always turn over when key is turned. also starter kept running once engine started. starter would not disengage even when key was turned to off position and removed
Feb 4, 2009 at 3:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty starter solenoid. Have starter tested. If starter is OK, suspect faulty ignition switch.
Thanks for using 2CarPros.com!
Feb 4, 2009 at 3:51 PM
