1999 Toyota Tacoma Engine missing badly
17,600 MILES • 6 CYL • 4WD • MANUAL
LESTER S.
I recently moved to Kona HI. I picked up my truck yesterday and everything was running fine. Today, I drove to the store and when I got back, I decided to clean my battery terminals with baking soda and water. While doing this, I broke the copper connector attached to the wire that runs to my fuse box and attaches to the positive post. I was unable to find an exact match but found a suitable substitute. Now when I start my truck, it misses badly and will not rev past 4000 rpms. I recently replaced all wires and spark plugs and everything was good until today. Thanks in advance
Mar 14, 2009 at 2:33 PM
  • 75,988 POSTS
Does the check engine light comes On when key at run position?
When you disconnect the battery the computer loses its memory and has to go thru a releaning process that may require 40 restarts to relearn it.
You can check the idle air control valve and throttle position sensor.
Mar 14, 2009 at 8:26 PM
