1999 Toyota Tacoma clutch
1999 TOYOTA TACOMA
111,000 MILES • 4 CYL • 4WD • MANUAL
CLINTONGGUESS
my clutch is losing pressure. I replaced my clutch slave cylinder and I am still having the same problem. what else could it be?
Jul 7, 2010 at 10:51 AM
2CARPRO JACK
  • 11,533 POSTS
Could be the clucth master cylinder that is bad or the rubber line between the slave and the hard line.If it is the rubber hose it willmost likely leak externally.Most likely the clutch master is bad
Jul 8, 2010 at 1:06 AM
