1998 Toyota Tacoma IAC Motor
1998 TOYOTA TACOMA
16,200 MILES • 4 CYL • 4WD • MANUAL
REARICH21
My IAC motor has gone bad in my tacoma. Mechanic wants five hundered to fix and the part is only 2. Heard it ian easy task but cant seem to find much about how to change one. Anyone with knowledge please help!!
Jun 24, 2010 at 6:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle's IAC valve/motor is located on the throttle body assembly. to replace it, drain the cooling system then remove the air cleaner hose and intake air connector. disconnect the control cables, air hose, vacuum hoses and electrical connectors at the throttle body. remove bolts/nuts, throttle body and gasket from the air intake chamber. disconnect remaining coolant hoses from bottom of throttle body. remove screws, IAC valve and gasket from throttle body to replace.
Jun 24, 2010 at 6:40 AM
REARICH21
Thanks alot, I was totally lost before that response.
Jun 24, 2010 at 6:48 AM
