My 1998 Toyota Tacoma will not start after it sits for several hours until I give it a shot of Starting fluid or try to crank it several times then it starts and runs fine. It will re-start if warm, but once it cools, same drill I have changed Plugs so far. Any more suggestions? Also in the morning it starts right up and runs for a min. and shuts off and than is very difficult to start. But than it will be ok for the rest of the day. terry
i ALSO USE LPG and still get a stall when I engage the trans with gasoline or gas when it's cold- so maybe the injectors need to be ?? sensors ?//?
Jun 6, 2009 at 9:00 AM
