1998 Toyota Tacoma
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
TP666
My 1998 Toyota Tacoma will not start after it sits for several hours until I give it a shot of Starting fluid or try to crank it several times then it starts and runs fine. It will re-start if warm, but once it cools, same drill I have changed Plugs so far. Any more suggestions? Also in the morning it starts right up and runs for a min. and shuts off and than is very difficult to start. But than it will be ok for the rest of the day. terry
i ALSO USE LPG and still get a stall when I engage the trans with gasoline or gas when it's cold- so maybe the injectors need to be ?? sensors ?//?
Jun 6, 2009 at 9:00 AM
KHLOW2008
  • 41,812 POSTS
Hi terry,
Always use the "reply to question" link so that notification will be sent to the technician attending to you and he can attend accordingly.
We shall continue working with the other post so that all history of replies can be in one post for easier reference.
Jun 6, 2009 at 6:57 PM
