1997 Toyota Tacoma overheating
18,600 MILES • 4 CYL • 2WD • AUTOMATIC
DAKNUCKLER
I have had a problem with overheating. I have replaced the radiator cap, thermostat, fan clutch, water pump, and now I replacing the radiator. hope it works. I have had the coolant checked for head gasket leak or cracked head they said it was ok. any ideas.
Oct 23, 2010 at 7:12 PM
  • 75,988 POSTS
Have you tried bleeding it out for airlock if not do so don't work get it pressure tested-
Oct 23, 2010 at 8:40 PM
