1997 Toyota Tacoma
BAMA360
Transmission problem
1997 Toyota Tacoma 4 cyl Two Wheel Drive Manual
I dont have much of a clutch.Can I ajust it
Sep 25, 2009 at 4:37 PM
  • 31,937 POSTS
Hi there ,
There is no clutch free pl adjustment, first check if the hydraulic fluid is low, and if so check for leaks at the slave & master Cly, you will need to check under the dash where the master Cly push rod enters the cabin for signs of fluid, start here.
mark (mhpautos)
Sep 25, 2009 at 5:08 PM
