1996 Toyota Tacoma My engine wont crank over
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
BAXTERSMURF18
  • 7 POSTS
For some time now my Toyota Tacoma has had a problem with the engine not cranking over, At first I thought it was just the cold, but now its warm and it still does the same thing. I put the key in the ignition and turn it over but it makes one click then stops. I am thinking it is my starter but most starters I have replaced have made a lot of clicking noises when turning over the ignition. Would my problem still be the starter? or is it another problem
Jun 7, 2010 at 4:58 AM
  • 75,988 POSTS
Hi baxtersmurf18, welcome to 2carpros and TY for the donation
No crank at all/nothing/nada:
Could be a blown fusible link, the starter, starter interlock relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Try shorting out the starter and see if it engages the engine
Jun 7, 2010 at 5:26 AM
BAXTERSMURF18
  • 7 POSTS
Yeah I turn over the ignition and I get one click each time I try to turn it over, eventually it starts but it takes about 3 to 15 times before I can get it to start. I first though it was the battery and cables, but I have replaced the battery and connections and all that so I am a bit confused. how would i short out the starter?
Jun 7, 2010 at 5:54 AM
  • 75,988 POSTS
At the starter solenoid there's a small wire colored black and white on the small terminal and a thick black wire on the battery terminal cross this 2 together wit ha screwdriver and see if it engages the engine.
Jun 7, 2010 at 11:35 AM
