1996 Toyota Tacoma Is the cruise control tied into the tran
STEVE382010
Transmission problem
1996 Toyota Tacoma 4 cyl Four Wheel Drive Manual
This is my problem , I took my truck into a local transmission shop to have a new clutch put in, when I got it back I went to work the next morning and tryed to use my crusie control . the light comes on in the cluster . But it will not set at all . I have tryed several times But wont work , It worked before I took the truck in for a new clutch . I called them and they said the cruise control dont hook into the transmission the speedometer does But it is working .
Aug 12, 2010 at 2:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The CC system does not physically connect to the transmission, it is electronically controlled. Check the fuse for the CC system. Also ensure the brake lights and back-up lights are working properly.
Aug 12, 2010 at 2:38 PM
