I would like to bypass my heater, it's leaking. Can you give me instructions on how to do this? or where to look for instructions. Thank you
Feb 26, 2010 at 2:23 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Locate the heater water inlet and outlet lines, you may have to put car on lifts, or ramp stands to get to heater core.
Disconnect negative wire off the battery, drain coolant out of cooling system.
Disconnect heater hoses from heater core.
Insert coupling between inlet and outlet hoses and tighten clamps. Add coolant. Reconnect battery. Start car to test lines.
Feb 26, 2010 at 5:46 AM
