1996 Toyota Tacoma 4x4 Not engaging
1996 TOYOTA TACOMA
122,000 MILES • 6 CYL • 4WD • AUTOMATIC
BAXTERSMURF18
  • 7 POSTS
I have a 1996 toyota tacoma lifed 3" with 33"x 12.5 tires on it. This is my first winter with it and I was told that the 4 wheel drive worked on it when I bought it but the other day it seems like it does not. I can put it in 4 hi and even 4 low and the front tires will never spin. When I put it in either 4 hi or low, I can feel the truck almost sit down like it is locking in 4 wheel drive but when I give it gas only my rear tires will spin, my front doesnt even try to move. It should be all automatic, I dont have manual locking hubs on the front. I dont know what to do? Any help, I need to get it working for the snowy hunting trips...
Dec 19, 2009 at 10:06 AM
RACEFAN966
  • 5,029 POSTS
I would first check the vacuum actuator on the front diff. Use the diagram below to see if it is working. Let me know what you find.
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_170.jpg
Dec 22, 2009 at 2:13 AM
BAXTERSMURF18
  • 7 POSTS
Thank you so much for responding but im kinda new to this 4x4 not working stuff, so For the vacuum pump, can you rent that from an automotive supply store like autozone or can you use anything with a vacuum.
following the diagram i would just test the vacuum ports a and b? is that right.
Dec 22, 2009 at 6:04 AM
RACEFAN966
  • 5,029 POSTS
Yes you test port a and b to see if it will hold vacuum. As for renting one don't know. You would have to call around and see. If you have to buy on don't buy one that only does vacuum get the one that will also bleed brakes this way you can use it for other things.
Dec 23, 2009 at 1:46 AM
BAXTERSMURF18
  • 7 POSTS
Thanks, I tested both ports and they both held pressure. I tried putting it in 4 wheel drive after I figured out it was not leaking vacuum pressure and it worked. So i think it might have had moisture in it or it was dirty and wasnt engaging.
Dec 29, 2009 at 12:28 PM
RACEFAN966
  • 5,029 POSTS
So it is fixed and working. Great that is the way it should work. It may be that it was just sticking and doing the vacuum test was all it needed. If there anything else you need just ask. Thanks for you support and have a great New Year.
Dec 30, 2009 at 1:55 AM
