1995 Toyota Tacoma MAF/VAF troubleshooting code
191,000 MILES • 4 CYL • 2WD • MANUAL
OSKERWIZE
  • 12 POSTS
The engine does not start only after pressing the gas pedal 3-4 times during cranking. I cleaned the MAF with CRC MAF cleaner but I still have the same code P0100. The fuel consumption has increased and there is a black soot that it spits out from the tail pipe when it starts, what to do?
Sep 13, 2010 at 1:23 AM
  • 75,988 POSTS
Bench test the airflow meter and test the wiring back to the computer. also check the coolant temperature sensor and fuel pressure-Double check the airflow meter it grounds the circuit opening relay to power the fuel pump
Sep 13, 2010 at 4:24 AM
OSKERWIZE
  • 12 POSTS
I disconnected the MAF electrical connector and test the engine if it will change, it did not. So I had it replace on the spot at Autozone and as I soon as I turned on the ignition the engine started. I have driven it for 100 miles since and no longer runs rich or have problems starting.
Sep 21, 2010 at 5:57 PM
