1995 Toyota Tacoma adjusting the timing
423,000 MILES • 4 CYL • 2WD • AUTOMATIC
DIGGITYDAVE
my father and i just replaced an engine head, and did not mark the timing on the distributor correctly so now,it will crank, but won't idle. is there anyway to reset the whole timing from 0? If so how?
Aug 14, 2010 at 9:54 AM
  • 75,988 POSTS
You need to verify the valve timing you could be 180deg off
Aug 14, 2010 at 1:34 PM
