1995 Toyota Tacoma
DPIERCEJR
Transmission problem
1995 Toyota Tacoma 4 cyl Four Wheel Drive Manual
I can shift into any gear without depress the clutch. The vehicle does not move it actual as it is in neutral
Is this a clutch or transmission problem?
Oct 4, 2009 at 8:42 AM
DOCFIXIT
  • 18,828 POSTS
If clutch disc was trashed or center broken out yes. Does shifter feel like it is engageing syncro detents? shifts in normal pattern?
Oct 4, 2009 at 8:49 AM
DPIERCEJR
shift is normal
Oct 4, 2009 at 9:07 AM
DOCFIXIT
  • 18,828 POSTS
Either clutch fault or input shaft gear damage
Oct 4, 2009 at 9:11 AM
DPIERCEJR
could it be the slave cylinder
Oct 4, 2009 at 9:16 AM
DOCFIXIT
  • 18,828 POSTS
No then it would grind the only way it can shift without grinding is if NO movement of input shaft
Oct 4, 2009 at 9:18 AM
DPIERCEJR
thank you
Oct 4, 2009 at 9:21 AM
