1991 Toyota Tacoma oil pan
WILLIAMMCCOY
Engine Performance problem
1991 Toyota Tacoma 4 cyl Four Wheel Drive Automatic
i've dropped the oil pan but can't get it out. what else do i need to remove to get it out. kind of new to this if you have suggestion's please advise. thank's
Feb 15, 2009 at 4:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need to remove the engine mounting bolts. Position a floor jack under the transmission and raise the engine/transmission assembly slightly in order to drop the pan the rest of the way out. Sometimes you can wiggle and jiggle that sucker out with a little wiggling and a lot of patience , but if the access whole is just too small then you will have to jack up the engine/tranny slightly.
Thanks for using 2CarPros.com!
Feb 15, 2009 at 4:53 PM
