1997 Toyota T-100 a/c clutch replacement
1997 TOYOTA T-100
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
DON MASSEY
How do I replace the t100 a/c compressor clutch
Jul 16, 2009 at 6:42 PM
  • 31,937 POSTS
HI there,
You will need to have the refrigerant removed form the system and remove the compressor, plug all lines, undo the shaft nut and pull the clutch assembly off the compressor with a suitable puller.
Mark (mhpautos)
Jul 16, 2009 at 6:52 PM
