1995 Toyota T-100 Heads gaskets
1995 TOYOTA T-100
CARLSO G.
Engine Mechanical problem
1995 Toyota T-100 4 cyl Two Wheel Drive Manual
The gaskets blow out, and when we open the engine we notice that the block was allrusted.
there are no craks on it but the rust is all over.
my question is can we clean the engine block and replace the gaskets and thet will fix the problem.
Also what can be the best procedure to clean and make it work.
Thank you so much for all our help
May 18, 2009 at 6:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
it's a lot of trouble but yes you can remove the engine block assembly and have it cleaned up at a machine shop.
May 29, 2010 at 3:04 PM
