1993 Toyota T-100 fuse removal
1993 TOYOTA T-100
134,000 MILES • 6 CYL • 4WD • MANUAL
DAD6963
how do you remove the 80A alt fuse in main engine compartment without breaking? mine seems to be stuck.
Mar 22, 2010 at 11:02 AM
USMCORDIE
Disconnect Battery.
Remove fuse and relay pannel on right front fender. (two bolts and its off)
Remove bottom cover of pannel.
Once you gain access, you will be able to remove the fuse link from the bottom of the pannel.
Remove two screws retaining wires to fuse link.
Mark wires. Installation is reverse of removal.
Apr 8, 2010 at 1:40 AM
