1993 Toyota T-100
1993 TOYOTA T-100
MOXTRAIN
Electrical problem
1993 Toyota T-100 6 cyl Four Wheel Drive Automatic
93 t100 has a new starter and ignition coil. Not getting even clicking when I turn the ignition into the last stage. There is power active in the car and all my fuses appear to still be good. I'm having trouble finding my starter relay as i've lost my kick panel cover. Not sure where I need to check next.
Sep 20, 2009 at 10:22 AM
First thing to do here is get the battery load tested to urle it out and also check for loose connections battery and starter side- I'm getting a conflicting location either The starter relay is in the fuse/relay block no.1 is in the engine compartment or in the left kick panel -sorry no pic available Check Alternator fuse 80amp and AM1 fuse 40amp and the following starter, park and neutral position switch and ignition switch Below is your starting system circuit
https://images.2carpros.com/forum/automotive_pictures/12900_T100_1.jpg
Sep 20, 2009 at 11:38 AM
