Transmission Vibration
VVFLYRICEVV
Hello guys, I have a 89 toyota supra 5-speed. I have a problem with the transmission..or related. Everything works fine..shifting from gears 1-5 and the reverse works fine. The problem is, is that when I hit any higher than 2900 rpm, the transmission and the car itself vibrates. I just put in a new flywheel, and a Spec Stage 3+ kit. I assumed it might be the driveshaft..so I attempted to disengage the clutch by holding the pedal down..and by accelerating the gas pedal..and it didn't change at all. Anything above 3k rpm it would vibrate. I am stumped and lost. I tried swapping another transmission..and the problem still persist. I duno if it can be both transmission be bad or something else.
May 19, 2007 at 9:34 PM
ZONER CHICK
  • 19 POSTS
How are your motor and tranny mounts?
May 20, 2007 at 12:32 AM
VVFLYRICEVV
The motor mount is new..however..the tranny mount is used. I decided to swap with another transmission that used the old tranny mount. My old transmission never reported this issue before..until i swap onto this new one.
May 21, 2007 at 5:45 PM
